JMF602 is a single chip, supports SATA II and USB2.0 to NAND flash interface. It is native design to provide higher
bandwidth for flash memory access.
JMF602 can support the maximum read and write speed to drive the limit of flash memory. JMF602 has the best
supporting to the latest NAND flash memory, including Samsung, Toshiba, Hynix, Micron and IM Flash. It also provides
the embedded hardware error correction code (ECC), wear leveling, and bad block management technology in this
chip. In order to resolve compatibility issue, JMF602 provides the on line firmware upgrade ability.
JMF602 provides embedded processor, internal masked ROM, data SRAM, SATA link/transport layer, SATA PHY,
USB 2.0 device controller and USB 2.0 PHY. Data swap between different interfaces can be done very efficiency by
DMA without CPU involvement. Based on the efficient architecture, the JMF602 can provide the best performance.
