ASC Serial Interface Async. Ba
消耗积分:2 | 格式:rar | 大小:333 | 2009-04-02
王超
分享资料个
The Siemens 16-bit Microcontroller family comprises two flash devices, the SAB 88C166
with 32 Kbytes on chip flash memory and the C167CR-16F with 128 Kbytes on chip flash
memory; both partitioned into 4 independent banks. The C167CR-16F can be
programmed more than 1000 times. They are suited most for applications requiring high
flexibility combined with standard hardware.
For instance, applications like motor control demand for a Flash device to be programmed
at the end of the production line in its final environment. Furthermore, prototyping and
small series are now much easier with the flash devices. To offer this flexibility, it is
necessary to enable in-circuit programming at the end of the production line or even in the
field. If that flexibility is not required, C166 Flash devices can also be preprogrammed by
means of dedicated programming boards.
This application note describes the necessary steps to be taken enabling in-circuit
programming for the C167CR-16F. The process of programming presented here is based
on the built-in boot strap loader of the C166 devices. All software including the
programming data is downloaded from a host PC into the internal RAM of the
microcontroller. Since the application requires only 1 Kbytes of internal RAM, no
assumptions about the hardware environment have to be made. The solution described
here employs a standard evaluation board . No changes to the board are necessary.
The application code is provided by our mail box Tel:+49 89 498431 and via our
distribution channels. For more detailed technical information regarding the devices
please refer to our data sheets.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
