DSP28335的MCBSP应用程序C语言源代码
消耗积分:0 | 格式:zip | 大小:222 KB | 2011-06-13
dplion
分享资料个
DSP28335DESCRIPTION:
.Digital loopback tests for the McBSP peripheral.
.Three different serial word sizes can be tested.
.Before compiling this project:
.* Select the serial word size (8/16/32) by using
.  the #define statements at the beginning of the code.
.This example does not use interrupts.  Instead, a polling
.method is used to check the receive data.  The incoming
.data is checked for accuracy.  If an error is found the error()
.function is called and execution stops.
.This program will execute until terminated by the user.
评论(0)
发评论
下载排行榜
