连接
SDA-Pin3
SCL-Pin5
VCC-3.3V
接地 - 接地
1 / 2
参考
https://github.com/ZhangGaoxing/windows-iot-demo/tree/master/KT0803L/Reference
包含什么
在 KT0803L.cs 文件中
/// /// Initialize KT0803L /// /// FM Channel ( Range from 70Mhz to 108Mhz ) /// Region /// Transmission Power /// PGA ( Programmable Gain Amplifier ) Gain public async Task InitializeAsync(double mhz, Country country = Country.CHINA, RFGAIN rfgain = RFGAIN.RFGAIN_98_9dBuV, PGA pga = PGA.PGA_0dB); /// /// Set FM Channel /// /// MHz ( Range from 70Mhz to 108Mhz ) public void SetChannel(double mhz); /// /// Set PGA ( Programmable Gain Amplifier ) Gain /// /// PGA public void SetPGA(PGA pga); /// /// Set Transmission Power /// /// public void SetRFGAIN(RFGAIN rfgain); /// /// Set Pre-emphasis Time-Constant /// /// Country public void SetPHTCNST(Country country); /// /// Set Mute Mode /// /// Mute when value is true public void SetMute(bool isMute); /// /// Set Standby Mode /// /// Standby when value is true public void SetStandby(bool isStandby); /// /// Set Bass Boost /// /// Boost Mode public void SetBassBoost(BassBoost boost); /// /// Cleanup /// public void Dispose();
如何使用
首先,您需要创建一个 KT0803L 对象。之后,您应该调用 InitializeAsync() 进行初始化。
KT0803L kt = new KT0803L(); // 108 MHz await kt.InitializeAsync(108);
您可以通过 3.5 毫米耳机插孔输入音频。之后,打开收音机,收听 FM 108 MHz。
如果要关闭传感器,请调用 Dispose()。
