SL811HS的Linux驱动程序源代码下载
消耗积分:10 | 格式:rar | 大小:333 | 2009-04-14
分享资料个
The SL811HS is a dual role host / slave embedded USB device. The SL811HS Linux Host Driver integrates the SL811HS into the Linux USB host stack, providing a complete embedded host solution for this operating system. Please refer to the User’s Guide for detailed information.
The structure for this release contains the following files:
In the Root directory
• Release Notes – This document
In the Docs subdirectory:
• SL811HSUserGuide.pdf – Setup environment, installation instruction, etc
• SL811HS Datasheet
In the Driver subdirectory:
• patch-2.4.4-SL811HS – Patch file that applies to the accelent kernel.
• hc_simple.c – Simple USB HCD front end
• hc_simple.h – Header file
• hc_sl811.c – The HCD driver
• hc_sl811.h – Header file
• hc_sl811_rh.c – USB virtual Root Hub functionality
评论(0)
发评论
下载排行榜
