When It’s Valuable To Understand the DL signal
• You are building the baseband signal and need to independently verify it
• You are feeding an unknown base station signal into a UE receiver and want to check what’s in the signal
• You have a low level interoperability problem
• You want to understand the structure of the downlink signal
• You want to find out why throughput results are not as high as you were expecting (track the HARQ processes in DL or UL)
