USBDeview 是一款可以列出当前连接到你的计算机上或者曾经连接到你的计算机上的所有 USB 设备的小型实用工具。根据列出的设备的名称和描述,该软件显示了串口号(如果提供),设备添加的日期以及最后连接的日期,VendorID 以及其它信息。你还可以选择断开或者卸载列表当中的任何设备,以及导出该列表为 Text/HTML 或者 XML 格式。USBDeview 还可以被用于从一台远程计算机(需要访问权)通过命令行收集 USB 设备。该软件是独立的,不需要进行安装。
USBDeview is a small utility that lists all USB devices that currently
connected to your computer, as well as all USB devices that you
previously used.
For each USB device, exteneded information is displayed: Device
name/description, device type, serial number (for mass storage devices),
the date/time that device was added, VendorID, ProductID, and more...
USBDeview also allows you to uninstall USB devices that you previously
used, and disconnect USB devices that are currently connected to your
computer.
You can also use USBDeview on a remote computer, as long as you login to
that computer with admin user.
