DS18B20X数据资料
消耗积分:0 | 格式:pdf | 大小:389 KB | 2011-11-02
分享资料个
The DS18B20X Digital Thermometer provides 9 to 12-bit (configurable) temperature readings which indicate the temperature of the device.Information is sent to/from the DS18B20X over a 1-Wire interface, so that only one wire (and ground) needs to be connected from a central microprocessor to a DS18B20X. Power for reading, writing, and performing temperature conversions can be derived from the data line itself with no need for an external power source.
评论(0)
发评论
下载排行榜
