如何产生一个 TD310电源电压四倍的直流电压
消耗积分:5 | 格式:rar | 大小:339 | 2009-05-12
分享资料个
The TD310 is a triple MOS or IGBT driver which
integrates all functions suited for compact and
highly secure driving such as adjustable Under
Voltage Lockout feature (UVLO), sense comparator
with alarm output and automatic shutdown,
independent operational amplifier, enable pin, and
global standby mode (e.g.: for portable applications).
The following describes how to generate a DC
voltage 4 times higher than the supply voltage of
the TD310. This voltage may be used as a
2.5W/60V DC supply.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
