HIP2030栅极驱动器可为开关电源类器件提供隔离的控制信号
Optically isolated gate drivers, that supply low level signal
voltages to drive power switches, provide many technical
advantages. These advantages are: high voltage isolation,
low capacitive coupling, immunity to magnetic pickup, and
the ability to remotely control gate drives without the effects
of inductive lead length. The gate driver must also supply the
required gate voltage and output current needed to slew a
specified dv/dt across a given gate capacitance. The Intersil
HIP2030 MCT/IGBT Gate Driver, used with fiber-optic links
or photo-couplers, provides an isolated gate drive that is
ideal for switching MCT or IGBT devices in power circuits.
