Designers of signal receiver systems often need to performcascaded chain analysis of system performancefrom the antenna all the way to the ADC. Noise is a criticalparameter in the chain analysis because it limits theoverall sensitivity of the receiver. An application’s noiserequirement has a signifi cant infl uence on the systemtopology, since the choice of topology strives to optimizethe overall signal-to-noise ratio, dynamic range andseveral other parameters. One problem in noise calculationsis translating between the various units used by thecomponents in the chain: namely the RF, IF/baseband,and digital (ADC) sections of the circuit.
