SRAM-based FPGAs are non-volatile devices. Upon powerup, They are required to be programmed from an external source. This procedure allows anyone to easily monitor the bit-stream, and clone the device. The problem then becomes how can you effectively protect your intellectual property from others in an architecture where the part is externally programmed?
