The LTC®1966 is a true RMS-to-DC converter that uses aDS computational technique to make it dramatically simplerto use, significantly more accurate, lower in powerconsumption and more flexible than conventional logantilogRMS-to-DC converters. The LTC1966 RMS-to-DCconverter has an input signal range from 5mVRMS to1.5VRMS (a 50dB dynamic range with a single 5V supplyrail) and a 3dB bandwidth of 800kHz with signal crestfactors up to four.
