The following tables contain maximum errors by grade for applications involving limited temperature spans. The tables reflect the worst case nonlinearities of the AD590, which invariably occur at the ends of the specified temperature range. The “trims” in each table refer to the error correction circuits on pages 4 and 5 of the AD590 data sheet (Figures 4 and 7a). All accuracies given below are ±°C. For example, ±1°C accuracy is required over the +25°C to +75°C range, then trimming a J grade device using the circuit of Figure 4 on the AD590 data sheet will result in a sensor of the required accuracy and range.
