AD590在限制温度范围内的精确度
消耗积分:10 | 格式:rar | 大小:333 | 2009-05-19
彭友旺
分享资料个
The following tables contain maximum errors by grade
for applications involving limited temperature spans.
The tables reflect the worst case nonlinearities of the
AD590, which invariably occur at the ends of the specified
temperature range. The “trims” in each table refer
to the error correction circuits on pages 4 and 5 of the
AD590 data sheet (Figures 4 and 7a). All accuracies
given below are ±°C. For example, ±1°C accuracy is
required over the +25°C to +75°C range, then trimming a
J grade device using the circuit of Figure 4 on the AD590
data sheet will result in a sensor of the required accuracy
and range.
评论(0)
发评论
下载排行榜
