基于定点DSP的高性能FFT谱估计
消耗积分:5 | 格式:rar | 大小:284 | 2009-05-20
分享资料个
在借鉴现有的快速傅里叶变换频谱校正算法的基础上,提出了改进的双窗法,并根据应用系统的特点,给出了改进的定点数字信号处理扩展精度快速傅里叶变换算法。从理论上分析了改良算法的可行性,通过仿真验证了改良算法的有效性。
Based on some established Fast Fourier Transform (FFT) spectrum correction algorithms, this paper presents an improved double-windowing method, as well as the improved extended-precision FFT scheme for fixed-point DSP. The feasibilities of the two reformative methods are discussed theoretically, and the validities are testified by the simulation results.
评论(0)
发评论
下载排行榜
