实时时钟X12xx的特性及应用
消耗积分:3 | 格式:rar | 大小:25 | 2009-05-23
分享资料个
A real time clock is a clock that keeps track of the time even when the system is turned off. Real time clocks run on a special battery that is not connected to the normal power supply of the system. In contrast, clocks that are not real-time do not function when the system is off.
Do not confuse a computer’s real-time clock with its CPU clock. Most of the real-time clocks operate at 32.768KHz comparing to the CPU clocks operate at either 33MHz or 50MHz. The CPU clock regulates the execution of instructions and other functions.
评论(0)
发评论
下载排行榜
