基于USB的运动控制平台及采集卡的设计
消耗积分:2 | 格式:rar | 大小:182 | 2009-06-04
万物死
分享资料个
本课题的研究目的是要开发一个基于USB 总线接口的电机控制平台,并带有数据采
集功能。主要包括两个部分:电机的运动控制和数据采集。控制的部分是实现在PC 机控制下的步进电机的运动,数据采集方面是监控外界例如温度、压力、湿度等环境条件,以及运动轨迹等数据的采集。
关键词:USB 总线;数据采集;步进电机
Design of Circuit Board with Moving Control and Gathering Data
WangJianMin, ZhangHongZhuang (Computer and Information Engineering Department, Shijiazhuang Railway Institute, Shijiazhuang,Hebei ,050043) Abstract: The purpose of this study is to make a board which is based on USB bus. The board include mainly two components:controller and gathering data. The controller is used to make step electromotor run under instruction of microcomputer and the gathering data detect thecircumstance temperature、pressure and so on.
Keywords: USB Bus; Gathering Data; Electromotor
评论(0)
发评论
下载排行榜
