OPA541 is the industry’s highest performance monolithic power amplifier. It can operate on ±40V power supplies and put out 5A continuously (10A peak). Internal current-limit circuitry can be user-programmed with a single external resistor to protect the amplifier and load from fault conditions. Under some conditions, the OPA541 may oscillate during current limit. In some applications, this is acceptable. However, you can improve stability during current limit by adding external compensation as shown in Figure 1.
