用NE5234 SA5234放大器设计输入级、中间级、输出级
消耗积分:5 | 格式:rar | 大小:233 | 2009-06-05
84784
分享资料个
The NE/SA5234 is a unique low-voltage quad operational amplifier
specifically designed to operate in a broadly diverse environment. It
is an enhanced pin-for-pin replacement for the LM324 category of
devices. Supply conditions can range from 1.8V to 6.0V with a
resultant current drain of 2.8mA,-700mA per op amp.
Most notable are the input and output dynamic range characteristics
of the individual op amps. The common-mode input voltage can
actually exceed the positive and negative supply rails by 250mV
with no danger of output latching or polarity reversal. In addition, the
output of each op amp will swing to within 50mV of the supply rails
over the full supply range.
评论(0)
发评论
下载排行榜
