LED的电源管理
消耗积分:0 | 格式:pdf | 大小:835 KB | 2013-01-25
刘明
分享资料个
A light-emitting diode (LED) is a semiconductor device that emits narrow-spectrum incoherent light when forward-biased.The color of the emitted light depends on the chemical composition of the semiconductor material used, and can benear-ultraviolet, visible or infrared. LEDs are more prevalent today than ever before, replacing traditional incandescent andfluorescent bulbs in many lighting applications. Incandescents use a heated filament, are subject to breakage and burnoutand operate at a luminous efficiency of 2% to 4%. Fluorescents are more efficient, at 7% to 12%, but require highdrive voltage and contain mercury, a toxic substance that may be eventually banned in certain countries. LEDs, however,produce light directly through electroluminescence, operate at low voltage and can deliver over 20% luminous efficiency.
评论(0)
发评论
下载排行榜
