提出一种对VLR用户数据进行处理的方法,采用面向对象的设计方法并以内存数据 库形式设计VLR数据库,通过哈希索引技术将用户数据存储在VLR数据库中,并能对存储在 VLR数据库中的移动用户数据进行编辑处理和访问。该方法可快速地进行用户数据的存储和 访问,易于设计和实现。并且具有很好的扩展性。 关键词:内存数据库;访问位置寄存器;哈希索引;面向对象设计 Abstract:A new method for VLR user data processing, is put forward. A kind of object-oriented scheme is firstly employed to design VLR database based on main memory database. Then user data are stored in VLR database by using hash index technique. Finally mobile user data of VLR database can be edited and accessed. The method which can quickly store and access user data, is easy to design and implement, and it has good expansibility. Keywords:Main Memory Database;VLR;Hash Index;Object-Oriented Design
