介绍了一种基于AT89C52 单片机的摩托车自动检测系统,简述了轴重、制动力与车速合一的检测系统的设计原理和结构,并对传感器的选用及测量电路的设计方法进行了论述。系统操作简便,具有很高的测量准确度和稳定性、可靠性,已在实际中得到应用。 关键词: 摩托车; 检测台; 单片机; 系统设计 Abstract : A motorcycle test system based on AT89C52 single2chip processor is designed. The design principle and structure of the test systemwhich integrates tests for axle weight ,braking forth and speed are presented. The proper appli2 cation of sensors and the method of designing signal circuit are discussed. Accurate test results can be obtained with sim2 ple operation. The system has good performance and reliability which has been used in practice. Key words : motorcycle ; test platform; single chip processor ; system design
