Abstract:The paper studies the designs of wide-area distributed cluster. Although these kinds of cluster have more complex structure, they can overcome limitations of traditional cluster and provide resolutions with good quality, large capacity and high performance compared to LVS. Base on a model of distributed cluster, named CG tree, the author design his algorithms to manipulate CG trees. The scheme can efficiently reduce the cost of intercommunication between different networks, and can automatically adjust tree to ensure high availability when cluster faults occur. The result of simulated experiments indicates that the system has quite good performance. Key words:Distributed cluster CG tree LVS
