快速傅立叶转换的实现和用PIC17C42计算快速傅立叶转换的
消耗积分:5 | 格式:rar | 大小:322 | 2009-06-27
分享资料个
Fourier transforms are one of the fundamental operations in signal processing. In digital computations, Discrete Fourier Transforms (DFT) are used to describe, represent, and analyze discrete-time signals. However, direct implementation of DFT is computationally very inefficient. Of the various available high speed algorithms to compute DFT, the Cooley-Tukey algorithm is the simplest and most commonly used. These efficient algorithms, used to
compute DFTs, are called Fast Fourier Transforms (FFTs).
This application note provides the source code to compute FFTs using a PIC17C42. The theory behind the FFT algorithms is well established and described in literature and hence not described in this application note. A Radix-2 Cooley-Tukey FFT is implemented with
no limits on the length of the FFT. The length is only limited by the amount of available program memory space. All computations are performed using double precision
arithmetic.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
