PIC17C42使用PWM输出时,对PWM频率和分辨方面的选
消耗积分:5 | 格式:rar | 大小:155 | 2009-06-29
31274
分享资料个
The PIC17C42 is equipped with two high frequency
Pulse Width Modulation (PWM) outputs. In a pulse
width modulated signal the period of the signal is
(usually) kept fixed, while the duty cycle is varied. In this
application note, we will discuss options in selecting
PWM frequency and resolution.
This application note assumes that the internal clock is
used for the time-base, which is typically the preferred
setup. Also, throughout this application note, PWM1
output is used in examples, Timer1 is assumed to be
the time-base.
评论(0)
发评论
下载排行榜
