V8330+FH8510资料
General Description The V8330 is a 1/3-inch with low voltage, highly integrated CMOS active-pixel digital image sensor. It captures image with rolling-shutter readout and provides high-quality color image. It has outputs of Bayer RAW image data and parallel digital format. The 46-pin CSP package is available. The V8330 can be programmed via I2C TM serial control bus or by an attached I2C flash memory at startup. By programming the internal register set, it performs the exposure time, offset correction DAC, and programmable gain control for different luminance condition.
Features : Output Format: RAW-10(parallel digital) : Bayer-RGB color filter array : On-chip 10-bit pipelined A/D converter : I 2C TM Interface : Power consumption: operating typ. 112mW (full resolution @ 60fps) : ABC (Automatic Black-Level Calibration) : BSC (Black-Sun Cancellation)
Key Specifications : Active Array Size: 768(H) x 576(V) : Optical Format: 1/3” Lens : Maximum Frame Rate: 60 frames per second : Pixel Size: 5.6um x 5.6um : Chief Ray Angle: 0°~ 25° : Scan Mode: Progressive : Power Supply: Analog: typ. 2.8V Core: typ. 1.8V I/O: 1.7V~3.3V : Input Clock: typ. 27Mhz : Pixel Clock: 27Mhz : Output Interface: 10-bit parallel digital output : Sensitivity: 11500 mV/Lux-Sec : S/N Ratio: 45 dB : Pixel Dynamic Range: 80 dB : Package: CSP
