人类舒适感涉及多方因素,具有主观性、多维性和模糊性,舒适度传感器是未来传感器发展应用的一个趋势。从应用的角度,提出并探讨了基于温湿度的模糊传感器舒适度合成方法,相关参量的隶属函数取典型的正态分布,考虑到多维概念合成的不完备性,提出了由例子推导建立规则库的方法。 关键词: 模糊; 舒适度; 传感器; 规则 Abstract : Comfortable sensation is affected by many factors including human’s consciousness ,multi2dimension space ,vagueness and fuzziness ,comfort degree sensors are the developing trend of sensors in the future. From the point of applications ,the synthesis of comfort degree about fuzzy comfort degree sensors based on temperature and dampness is proposed and researched. The membership function for relative variable is typical normal distribu2 tion. Thought of the imperfection for synthesis multidimensional concept ,a method for building the set of rules by examples is proposed. Key words : fuzzy ; comfort degree ; sensor ; rule
