对16位微控制器C163-16F内的128 KBytes闪速
消耗积分:3 | 格式:rar | 大小:73 | 2009-07-01
五斤麻辣油
分享资料个
Siemens C163-16F 16-bit microcontrollers provide 128 KBytes Flash memory on-chip.
This application note gives hints and examples for in-system programming of C163-16F Flash devices. In-system programming is supported by the Windows-based OTP/ Flash memory programming tool “Memtool”.
1 Flash Memory Overview 3
2 Flash Memory Configuration. 5
3 Flash Command Register. . . . 6
3.1 Handling of Flash addresses.. 7
4 Programming Examples. . . . . 8
4.1 Example 1 „Read Flash Status“  8
4.2 Example 2 „Burst Write“. . . . 9
4.3 Example 3 „Sector Erase“. . 11
5 Flash operation control by using the Flash Status Register FSR  12
6 Memtool - The OTP/ Flash Memory Programming Tool  13
Appendix.  15
A flash.h 15
B flash.c 17
评论(0)
发评论
下载排行榜
