介绍32位微控制器的同异步串行接口的波特率计算(分数除法器)
消耗积分:5 | 格式:rar | 大小:39 | 2009-07-01
分享资料个
The Asynchronous/Synchronous Serial Interface of the 32-bit microcontrollers allows
programming of the desired baudrate very precisely in asynchronous modes, depending on the CPU clock rate. This ApNote describes the programming of the baudrate generator (fractional divider and baudrate reload timer) and provides an utility program for optimization of this step.
1 Baudrates in Asynchronous Mode  3
1.1 Using the fixed Input Clock Divider  4
1.2 Using the Fractional Divider   4
2 Comparision between Fractional Divider and Fixed Dividers  5
2.1 Improved Baudrate Range   5
2.2 Improved Baudrate Accuracy   5
3 Baudrate Calculation Program ASC.EXE   6
评论(0)
发评论
下载排行榜
