87LPC76X的IIC从程序
消耗积分:5 | 格式:rar | 大小:37 | 2009-07-01
分享资料个
The 87LPC76X Microcontroller combines in a small package the
benefits of a high-performance microcontroller with on-board
hardware supporting the Inter-Integrated Circuit (I2C) bus interface.
The 87LPC76X can be programmed both as an I2C bus master, a
slave, or both. An overview of the I2C bus and description of the bus
support hardware in the 87LPC76X microcontrollers appears in
application note AN464, Using the 87LPC76X Microcontroller as an
I2C Bus Master. That application note includes a programming
example, demonstrating a bus-master code. Here we show an
example of programming the microcontroller as an I2C slave.
评论(0)
发评论
下载排行榜
