8*8*8光立方 595阳极驱动 程序
#include《reg52.h》
#include 《intrins.h》 //空语句调用头文件
#include“zimo.h”
#define uchar unsigned char
#define uint unsigned int
sbit DS=P1^0;
sbit CLK=P1^1; //74HC595的SH-CP(11脚)
sbit STB=P1^2; //74HC595的时钟和输出锁存(12脚)
/*坐标数组*/
uchar code shu[8]={0,1,2,3,4,5,6,7}; //十进制数选
uchar code x1[8]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//595数据
uchar code y1[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//595使能
uchar code z1[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};//层扫描
/*亮度调节延时*/
void delay(unsigned int i)
unsigned int j;
for(;i》0;i--)
for(j=5;j》0;j--);
