lm7805 POSITIVE VOLTAGE REGULATORS
消耗积分:0 | 格式:pdf | 大小:1797KB | 2014-09-07
rcm72182
分享资料个
The L7800 series of three-terminal positive regulators is available in TO-220,TO-220FP,TO-220FM,TO-3 and D2 PAK packages and several fixed output voltages, making it useful in a wide range of applications。 These regulators can provide local on-card regulation, eliminating the distribution problems associated with single point regulation。 Each type employs internal current limiting,thermal shut-down and safe area protection, making it essentially indestructible。 If adequate heat sinking is provided,they can deliver over 1A output current。 Although designed primarily as fixed voltage regulators,these devices can be used with external components to obtain adjustable voltage and currents。
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
