基于μc/OS-II的多传感器测控系统研究
消耗积分:3 | 格式:rar | 大小:247 | 2009-07-09
分享资料个
移植典型的实时嵌入式操作系统μc/OS-II 到SPCE061 高性能处理器平台,结合工程项目对于温度湿度氧浓度的要求,构建了实时嵌入式多传感器测控系统。介绍了硬件电路的设计,研究了实时操作系统任务分配和移植技术。实践试验证明:温度湿度氧浓度三个参数测
控范围和精度达到了设计目标,同时系统具有数据传输保存等功能,满足了工程要求。
关键词:多传感器;实时操作系统;嵌入式系统;移植;测控
Abstract: This paper constructed a real time embedded multi-sensors measuring and controlling system by transplanting the typical real-time operation system μc/OS-II to the high-performance micro-processor SPCE061 and combining the engineering request to the temperature ,humidity and O2-thickness. It introduced the design of the hardware and studied the task allot of the real-time operation system and the transplanting technics. The experiments showed that the measuring and controlling range or precision satisfied the plan aim of the three parameters about temperature ,humidity and O2-thickness, simultaneously the target system also had the functions as data transition and storing ,etc. which contented to the engineering demands.
Keywords: Multi-sensors; Real Time Operation System (RTOS); the Embedded System;
Transplant Techniques; Measuring and Controlling
评论(0)
发评论
下载排行榜
