FCS 是工业过程控制系统的必然趋势,就系统中的智能传感器进行结构分析,并根据其特点,论述并分析了其数据处理方法的特性,并提出了一些具有先进性的数据处理方法,对处理平稳传感器数据和非平稳传感器数据都有适应性。 关键词: 现场总线控制系统; 智能传感器; 指数平滑; 平稳; 非平稳 Abstract : FCS is the certainly tendency of industrial control system. Structure analysis of intelligent sensors in this system is done , and based on it ,some advanced methods of processing the data is brought forward. These methods is suitable to stability and non2stability date of intelligent sensors. Key words : fieldbus control system(FCS) ; intelligent sensors ; exponent moving ; stability ; non2stability
