The OMAP-L13x series is a family of low-power DSP+ARM® applications processors geared for portable applications。 These processors require a specific power-on and power-off sequence for reliable operation。This sequence is described and an inexpensive, discrete sequencing solution is provided that uses the TPS650061 Power Management IC。This circuit can be adapted for other Power Management ICs and processors as well。
