Self-Calibrating, 16-Bit ANALOG-TO-DIGITAL CONVERTER ADS1100
消耗积分:0 | 格式:pdf | 大小:701KB | 2014-12-04
liuxiguang210
分享资料个
The ADS1100 is a precision, continuously self-calibrating Analog-to-Digital (A/D) converter with differential inputs and up to 16 bits of resolution in a small SOT23-6 package. Conversions are performed ratiometrically, using the power
supply as the reference voltage. The ADS1100 uses an I2C-compatible serial interface and operates from a single power supply ranging from 2.7V to 5.5V。
评论(0)
发评论
下载排行榜
