应用霍耳开关元件检测液压缸位移原理的研究
消耗积分:5 | 格式:rar | 大小:294 | 2009-07-13
李军
分享资料个
位移检测装置是电液位置伺服控制、同步控制系统中的关键环节。基于霍耳效应,本文提出可集成的液压缸位移检测方法,详细介绍了该方法的原理、传感器与液压缸的集成方式、结构、特点和使用场合。通过实验, 研究了液压缸运动速度变化、传感器探头与活塞杆表面间隙变化及活塞杆凹槽涂层对测量信号的影响,同时设计了传感器的信号处理电路。
关键词: 液压缸 位移检测 霍耳传感器
Abstract :Position measurement is a key technique of elect ro - hydraulic cont rol system. Based on vortex principle and hall effect , a position measuring method that can be integrated into hydraulic cylinder was presented. In the paper the measuring principles , integrated way of sensor in hydraulic cylinder , feature and applying occasion are analyzed in detail. By means of experiment s , the influ2 ence on measurement signal of hydraulic cylinder velocity , gap between sensor and piston rod and smearing layer on rod surface are studied. At the same time , the elect ronic circuit of measurement sensor is designed.
Keywords : Hydraulic cylinder , position measurement  Hall t ransducer.
评论(0)
发评论
下载排行榜
