TTP229_16键/8键触摸检测IC资料(英版)
消耗积分:1 | 格式:pdf | 大小:361KB | 2015-05-28
ljqj1
分享资料个
The TTP229 TonTouchTM IC is capacitive sensing design specifically for touch pad controls. The device built in regulator for touch sensor. Stable sensing method can cover diversity conditions. Human interfaces control panel links through non-conductive dielectric material. The main application is focused at replacing of the mechanical switch or button. The ASSP can independently handle the 8 touch pads or up to 16 touch pads。
评论(0)
发评论
下载排行榜
