0.1Hz 10MHz频率计
消耗积分:10 | 格式:rar | 大小:444 | 2008-05-19
xymbmcu
分享资料个
#include
unsigned char t=0,yichu=0,fenpin;
sbit B153=P2^0;
sbit A153=P2^1;
sbit GATE=P2^6;
sbit CLR=P2^7;
sbit P33=P3^3;
void t0(void)interrupt 1
{t++;
yichu=2;        //定时器0溢出,yichu=2
void t1(void)interrupt 3    //计数器1溢出,yichu=1
{TCON=0;
yichu=1;
TH1=0xff;
TL1=0xff;
void delay(void)      //1s软件延时
{unsigned int i=500,j;
while(i)
 {i--;
 j=250;
 while(j)
  {j--;}
unsigned char table(unsigned char x) //软件查表输出
{unsigned char code n[10]={0xee,0x82,0xdc,0xd6,0xb2,0x76,0x7e,0xc2,0xfe,0xf6};
return(n[x]);
display(float f)      //以测出的频率串行输出
{unsigned long x;
unsigned char a[5]={0,0,0,0,0},i=0,j;
if(f!=0){
if((f<10000)&&(f>1))     //正常显示
 {if(f>1000)f=f-1;     //软件修正频率偏差
 while(f<1000)
  {f=f*10;
  i++;
 x=f*10;
 a[4]=x%10;
 if(a[4]>=5)f=f+1;;
 x=f;
 a[1]=x%10;
 a[2]=(x/10)%10;
 a[3]=(x/100)%10;
 a[4]=(x/1000)%10;
 for(j=0;j<5;j++)
  {a[j]=table(a[j]);}
 a[i+1]++;
 a[0]=0;
else if(f>=10000)      //以科学计数法显示
 {while(f>=1000)
  {f=f/10;
  i++;
 x=f;
 a[4]=(unsigned char)((float)((f-x))*10);
 if(a[4]>=5)x++;      //四舍五入
 a[2]=x%10;
 a[3]=(x/10)%10;
 a[4]=(x/100)%10;
 a[0]=i+2;
 for(j=0;j<5;j++)
  {a[j]=table(a[j]);}
 a[4]++;
 a[1]=0x7c;
else
 {x=f*10000;       //频率值小于1
 if((x%10)>=5)x=x+10; //四舍五入
 x=x/10;
 a[1]=x%10;
 a[2]=(x/10)%10;
 a[3]=(x/100)%10;
 a[4]=(x/1000)%10;
 for(j=0;j<5;j++)
  {a[j]=table(a[j]);}
 a[4]++;
 a[0]=0;
for(j=0;j<5;j++)   //串行
 {SBUF=a[j];
 while(TI==0);}
cepin()
{unsigned char i;
float sj;
unsigned long js;//时间、计数的拼音首字母
float f;  //f为频率
TMOD=0xd9;
t=0;
TH0=0;
TL0=0;
TH1=0;
TL1=0;
GATE=0;
TCON=0x50;
GATE=1;
delay();
GATE=0;
for(i=0;i<250;i++){}    //延时1ms
sj=((float)(TH0*256+t*65536+TL0))/1000000.0;
js=(long)TH1*256+TL1+1;
f=(js/sj)*fenpin;
display(f);
panduan()
{float zhouqi;
B153=1;
A153=1;
TMOD=0x51;
TH0=0xce;  //定时器0=12.8ms
TL0=0;
TH1=0xff;  //计数器1=100个脉冲
TL1=0x9c;
TCON=0x50;
while(yichu==0);
TCON=0;
if(yichu==1) //计数器先溢出:在12.8ms内测得的脉冲过多,说明频率较高
 {fenpin=128;//转为测128分频后的频率
 cepin();}
else    //计时器先溢出:100个脉冲的时间比较短,即频率较低,可以减少分频数
 {yichu=0;
 B153=1;
 A153=0;
 TH0=0xc1; //定时器0=16ms
 TL0=0x80;
 TL1=0x9c;
 TCON=0x50;
 while(yichu==0);
 TCON=0;
 if(yichu==1)   //计数器先溢出:在16ms内测得的脉冲过多,说明频率较高
  {fenpin=16;//转为测16分频后的频率
  cepin();}
 else   //计时器先溢出:100个脉冲的时间比较短,即频率较低,用2分频测周期
  {B153=0; //以下是测周期部分
  A153=0;
  TH0=0;
  TL0=0;
  t=0;
  TMOD=0x09;
  TR0=1;
  GATE=1;
  while(P33==0);
  GATE=0;
  while(P33==1);
  TR0=0;
  zhouqi=(TH0*256+t*65536+TL0)/1000000.0;
  if(zhouqi<0.001) //若周期太小,则转为测原频率
   {fenpin=1;
   B153=0;
   A153=0;
   cepin();}
  else{display((1.0/zhouqi));}
main()
IE=0x8a;
while(1)
 panduan(); //判断原频率属于哪个范围,并调用相应函数测其频率
 delay();
评论(0)
发评论
下载排行榜
