自动增益控制电路已广泛用于各种接收机、录音机和信号采集系统中,另外在光纤通信、微波通信、卫星通信等通信系统以及雷达、广播电视系统中也得到了广泛的应用。
本课题主要研究应用于音频放大的前级电压放大,因此设计的电路需容纳的频带范围应较宽,以至于使语音信号通过。由于语音信号的频带范围为300hz-3400hz,所以该电路所应设计的频带范围应在300hz-3400hz之间,并且电路应该实现增益的闭环调节,通过此电路可以实现增益的自动调整,以至于使音频信号强时自动减小放大器的倍数,信号弱时自动增大放大器的倍数,从而实现音量的自动调节。
本课题介绍了自动增益控制的概念原理以及对自动增益控制放大器各部分的工作原理,最后对系统的测试结果以及设计与实现中应该注意的问题也做了详细分析。
关键词: 放大器;自动增益控制; 电压跟随器; 滤波器
ABSTRACT
The automatic gain control electric circuit has been widely used in all kinds of receivers、tape recorders and signal gathering systems, and also been used in communications system radar, the broadcast television system and optical fiber communications, microwave communications, satellite communications.
This topic mainly studies to the applies to the front level voltage amplification of the audio frequency amplification, therefore the frequency band scope of the electric circuit should be wider that can make the pronunciation signals to pass. Because the frequency band scope of the pronunciation signal is 300 Hz-3400 Hz, so the frequency band scope of our electric circuit should be designed within 300 Hz-3400 Hz. And the electric circuit should realize the closed loop adjustment which increases, it may realize the automatic control through this electric circuit which increases when the tonic train signal is strong automatically that it can reduce the multiple of the amplifier, and when the signal is weak that it can automatically increase the amplifier the multiple, so that can realize the volume with automatic control.
This topic also introduced in the concept principle of the automatic gain control as well as to automatically increases the amplifier every part of principle of work the detailed introduction, and it pays attention to the question to the test result of this system .Finally we have make some analysis to the design.
Key words:Amplifier; Automatic Gain Control; AGC;Voltage follower;Filter
目录
摘 要…………………………………………………………………………………..1
第1章 引言………………………………………………………………………..4
第2章 自动增益控制……………………………………………………….….4
2. 1自动增益控制…………………………………………………………………4
2.1.1自动增益控制基本概念………………………………………………..4
2.1.2自动增益控制的原理……………………………………….………….5
2. 2自动增益控制放大器…………………………………………………………5
2. 3本课题的研究内容…………………………………………………………….5
第3章 自动增益控制放大器的电路设计……………………………………6
3. 1方案选择……………………………………………………………………….6
3. 2压随器工作原理………………………………………………………………8
3. 3整流电路工作原理……………………………………………………………8
3. 4滤波……………………………………………………………………………9
3. 5增益控制工作原理…………………………………………………………….9
3. 6电路元器件选择………………………………………………………………10
3.6.1运算放大器………………………………………………..………….10
3.6.2场效应管的选择……………………………………………………...11
3.6.3其他元器件的选择…………………………………………………...11
第4章 放大器电路的调试及实验结果………………………………………12
4. 1放大器电路的调试……………………………………………………………12
4. 2实验结果及存在问题…………………………………………………………12
第5章 总结………………………………………………………………………...14
参考文献………………………………………………………………………………15
附 录……………………………………………………………………………………15
致 谢……………………………………………………………………………………16
第1章 引言
随着微电子技术、计算机网络技术和通信技术等行业的迅速发展,自动增益控制电路越来越被人们熟知并且广泛的应用到各个领域当中。自动增益控制线路,简称AGC线路,A是AUTO(自动),G是GAIN(增益),C是CONTROL(控制)。它是输出限幅装置的一种,是利用线性放大和压缩放大的有效组合对输出信号进行调整。当输入信号较弱时,线性放大电路工作,保证输出声信号的强度;当输入信号强度达到一定程度时,启动压缩放大线路,使声输出幅度降低,满足了对输入信号进行衰减的需要。也就是说,AGC功能可以通过改变输入输出压缩比例自动控制增益的幅度,扩大了接收机的接收范围,它能够在输入信号幅度变化很大的情况下,使输出信号幅度保持恒定或仅在较小范围内变化,不至于因为输入信号太小而无法正常工作,也不至于因为输入信号太大而使接收机发生饱和或堵塞。在电路设计中,这种线路被大量的运用,从尖端的雷达技术到日常的广播电视系统,自动增益控制无疑很好的解决了各种技术中存在的信号强度问题。目前,实现自动增益控制的手段有很多,在本文中,主要研究的是如何以放大器来实现自动增益控制的目的,也就是自动增益控制放大器。
全部2条评论
