嵌入式设备与以太网互连系统的设计
消耗积分:3 | 格式:rar | 大小:148 | 2009-08-04
刘伟
分享资料个
针对当前工业控制、智能仪器、信息家电等领域大量嵌入式设备需要接入互联网的现状,提出了一种基于IP2022 单芯片的解决方案,实现了带有RS-485 串口的嵌入式设备与以太网的连接。主要介绍了基于IP2022 芯片的硬件总体结构、系统的接口电路和软件设计。具有体积小、功耗低、开发周期短的特点,实用价值很高。
关键词:嵌入式设备;IP2022;RS-485;以太网接入
Abstract:At present many embedded equipments need to connect Internet in the field of industrial control , intelligent instrument and information appliance, etc. In allusion to the actuality, we put forward a solution based on a single chip IP2022.It realizes the connection between embedded equipment with RS485 serial interface and Ethernet. The paper mostly introduces the IP2022 chip, the hardware structure, the system’s interface circuit and
the software design. The advantages of the project are small bulk, low power waste, short development time and high practicality value.
Key words:Embedded equipment;IP2022;RS485;Ethernet connection
评论(0)
发评论
下载排行榜
