D-S证据理论在多平台协同数据融合中的应用
消耗积分:5 | 格式:rar | 大小:196 | 2009-08-04
好名字
分享资料个
为解决多平台协同数据融合问题,采用基于D-S 证据理论的数据融合方法,分析了该理论在多平台协同数据融合中的应用原理,并将此方法运用于舰船类型的识别。通过
MATLAB 仿真计算对D-S 方法在多平台协同数据融合和单平台数据融合中的应用进行了比较,
验证了该理论在多平台协同数据融合中的有效性和实用性。
Abstract: A method of data fusion based on D-S evidential theory is applied to
resolve cooperative multi-platform data fusion problems,The basic theory is
analyzied in application and this method is applied to cooperative multi-platform
data fusion for target recognition of warship . The application of D-S method
in cooperative multi-platform data fusion is compared with that in single
platform data fusion by MATLAB simulative computation, the results indicate that
the theory is effective and practicable.
Keywords:D-S evidential theory, Multi-platform, Cooperative data fusion
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
