AT89C2051_8-Bit Microcontroller with 2K Bytes Flash
消耗积分:0 | 格式:zip | 大小:242KB | 2016-03-31
fly_young
分享资料个
The AT89C2051 is a low-voltage, high-performance CMOS 8-bit microcomputer with 2K Bytes of Flash programmable and erasable read only memory (PEROM). The device is manufactured using Atmel’s high density nonvolatile memory technology and is compatible with the industry standard MCS-51™ instruction set. By combining a versatile 8-bit CPU with Flash on a monolithic chip, the Atmel AT89C2051 is a powerful microcomputer which provides a highly flexible and cost effective solution to many embedded control applications.
评论(0)
发评论
下载排行榜
