at89c52中文资料
消耗积分:10 | 格式:rar | 大小:666 | 2008-06-17
分享资料个
 at89c52单片机是美国ATMEL公司生产的低电压,高性能CMOS 8位单片机,片内含8K bytes的可反复擦写的Flash只读程序存储器和256bytes的随机数据存储器(RAM),器件采用ATMEL公司的高密度,非易失性存储技术生产,与标准MCS-51指令系统及8052产品引脚兼容。功能强大的at89c52单片机适合于许多较为复杂控制应用场合。
The AT89C52 is a low-power, high-performance CMOS 8-bit microcomputer with 8K
bytes of Flash programmable and erasable read only memory (PEROM). The device
is manufactured using Atmel’s high-density nonvolatile memory technology and is
compatible with the industry-standard 80C51 and 80C52 instruction set and pinout.
The on-chip Flash allows the program memory to be reprogrammed in-system or by a
conventional nonvolatile memory programmer. By combining a versatile 8-bit CPU
with Flash on a monolithic chip, the Atmel AT89C52 is a powerful microcomputer
which provides a highly-flexible and cost-effective solution to many embedded control
applications.
评论(4)
发评论
ysm2259 2013-09-11
0 回复 举报
谢谢分享 收起回复
2011-06-14
0 回复 举报
长来贵网站,今天刚注册,多多学习。 收起回复
全部评论
下载排行榜
全部4条评论
