COM Programming by Example
消耗积分:1 | 格式:pdf | 大小:4514KB | 2016-06-16
幸福零距离
分享资料个
Welcome to the world of the Component Object Model (COM). If there was ever a subject that lent itself nicely to examples, it’s this one. None of the API’s, configuration files, classes, wizards, or helper applications of COM can stand alone — you need an example of how to use them all together in order to know how to do anything. And when you have an example and know what you’re doing, adding COM to your application will take up almost none of your development time.
评论(0)
发评论
下载排行榜
