AD7814,pdf datasheet (Temperat
消耗积分:2 | 格式:rar | 大小:433 | 2009-08-23
王兰
分享资料个
The AD7814 is a complete temperature monitoring system in a
SOT-23 package or 8-lead MSOP package. It contains a band
gap temperature sensor and 10-bit ADC to monitor and digitize
the temperature reading to a resolution of 0.25°C.
The AD7814 has a flexible serial interface that allows easy interfacing
to most microcontrollers. The interface is compatible
with SPI®, QSPI™, and MICROWIRE™ protocol, and is also
compatible with DSPs. The part features a standby mode that is
controlled via the serial interface.
The AD7814’s wide supply voltage range, low supply current,
and SPI-compatible interface make it ideal for a variety of
applications, including personal computers, office equipment,
and domestic appliances.
评论(0)
发评论
下载排行榜
