AD6630,pdf,datasheet (Differen
消耗积分:3 | 格式:rar | 大小:129 | 2009-08-25
微风挽雨
分享资料个
The AD6630 is an IF gain block designed to interface between
SAW filters and differential input analog-to-digital converters.
The AD6630 has a fixed gain of 24 dB and has been optimized
for use with the AD6600 and AD6620 in digitizing narrowband
IF carriers in the 70 MHz to 250 MHz range.
Taking advantage of the differential nature of SAW filters, the
AD6630 has been designed as a differential in/differential out
gain block. This architecture allows 100 dB of adjacent channel
blocking using low cost SAW filters. The AD6630 provides
output limiting for ADC and SAW protection with ,10° phase
variation in recovery from overdrive situations.
Designed for “narrow-band” cellular/PCS receivers, the high
linearity and low noise performance of the AD6630 allows for
implementation in a wide range of applications ranging from
评论(0)
发评论
下载排行榜
