AU9254_USB集线器控制器技术参考手册_英版
消耗积分:1 | 格式:pdf | 大小:505KB | 2016-10-03
asdsdfg309
分享资料个
The AU9254 is an integrated single chip USB hub controller designed for the emerging industry-standard Universal Serial Bus (USB). The AU9254 supports four USB downstream ports. Each downstream port has power switch control, and over-current sensing.
评论(0)
发评论
下载排行榜
