AD826,pdf datasheet (Operation
消耗积分:5 | 格式:rar | 大小:231 | 2009-08-31
12268
分享资料个
The AD826 is a low cost, wide band, high performance dual
operational amplifier which can drive heavy capacitive and
resistive loads. It also achieves a constant slew rate, bandwidth
and settling time over its entire specified temperature range.
The AD826 (Figure 35) consists of a degenerated NPN differential
pair driving matched PNPs in a folded-cascode gain stage.
The output buffer stage employs emitter followers in a class AB
amplifier which delivers the necessary current to the load while
maintaining low levels of distortion.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
